Leitz Elmar 5cm -- what is this thing!?
chambrenoire
1:12 PM
Stockholm, Sweden
Checked out the Sunday flea market as usual here in Stockholm and found this weird thing, which I bought for the equivalent of $8USD. Anyone know or can hint at what exactly it is? Some Elmar 5cm lens tester/calibrator thingy?
Thanks in advance!
Could this be used as a focus checker if one were adjusting LTM lenses? Looks like you'd get ground glass in the film plane and wouldn't have to use a camera with the back open/off.
Seems like it might well be worth the $8 and a bit more!
Rob
Checked out the Sunday flea market as usual here in Stockholm and found this weird thing,...
More correctly, "these weird things".
It appears to be a Focoslide (OOZAB) with a focusing mount (ZOOXY) attached. The mount should unscrew revealing the standard LTM mount. The ZOOXY is designed to accept the 50mm f/3.5 Elmar.
Focoslide. You put the camera body on one barrel and slide the focus glass in position, set the focus, slide the camera in position and take the shot. Mostly used on the Reprovit type copy stands, but you can also adapt it to the Leica VALOY enlargers (special arm to hold the stage in position). It works, but it is slow and rather cumbersome. The focussing helicoil is the most interesting parts - you can adapt other lenses to it (enlarging lenses) and have a functioning focus. I have one and occasionally use the helicoid barrel on a bellows outfit. Admittedly mainly because I have it - not for ease of operation!
Joking aside, it's called a Focalslide. You mount camera on the slide (different models for LTM & M). Then mount it to a copying easel. Much like the Visolflex, you could mount different lenses, or the head of certain lenses, or the collapsed position of the Elmars and Summircons using various adpaters, The ground glass is missing the eyepiece (a tube with diopters). But you mounted your camera, then the lens and adapter, and move the whole thing up & down until your subject is in focus on the ground glass. The you slide the camera horizontally to replace the ground glass and take the picture.
It was used primarily for document copying (in my experience) because once focused you could just change the pages and snap away.
I suppose people don't know what microfiche is?
