Leitz Focotar 4.5/50 for Leica M
Kent
Finally at home...
7:59 PM
Germany
Wait a minute! The Focotar is an old enlarger lens! How on earth would you use that on a Leica M body?
Well, like that:
By using a home-made helicoid adapter with rangefinder coupling.
But, does is work? Oh yes, it does:
Pretty sharp, rather low contrast and with a certain "glow" at contrast edges.
I really like it and it's a truly unique lens.
"By using a home-made helicoid adapter with rangefinder coupling."
Any chance to see more info about it? Please.
I have couple of miniature enlarger lenses, which I not use for enlarging, but it would be great to have them coupled with RF.
It's rather complicated. I could never have done it on my own. The basic work Henry, a friend of mine, has done. He is some kind of lens tinkering genius.
It all started with a version for Sony NEX cameras. NEX adapter as a bayonet mount, a turned aluminium ring which holds the helicoid, basically a spiral walk and a taking ring with an M39 thread.
>> Here << Henry describes it in another forum.
He later tried a version for Leica M mount using a Leica M8 and trial-and-error. With this he was able to adapt a Rodenstock enlager lens to the M8.
But it didn't work with the Focotar which has a different flange distance.
Since I own an M(240) with live-view, I wanted to optimize it and get my old Leitz enlarger lenses working. I bought a Leica-version from Henry and tried to use different thread rings but none did work. I found out that I needed an 8mm one and Henry turned one for me. That worked out great and I could adjust it to the rangefinder.
It is necessary to say that this helicoid only works with a 50mm lens. Other focal lengths would need different thread pitch.
And my Varob 3.5/50 cannot be adapted, since it has the same flange distance as the Elmar 3.5/50 (which is optically the same). But I can use that one with a helicoid adapter on my Sony A7II.
Yes, it is not cheap.
Alpa Kinoptik Paris Apochromat 150mm f/2.8 Lens Alpa Mount Rare E+
9 watching
$6,599.00
Sweet Optic! I Love “garage hot rodding” the Leica! Another Sweet lens is the Leitz F4.5 42 mm coated Mikro Summar. A bitsy little lens with a tiny optic that pulls off full frame wide angle with perfection. I have a one on my Working UR Leica and am in Awe of its images.
