mtokue
Hi all,
I recently managed to get a hold of two of these beauties, actually quite reasonably on the bay
What I am trying to find out is the specs to these two, They look very similar but, are slightly different. One will fit onto my Summilux without a problem but the other wont..... The difference seems to be because of the thickness of the brass collar that can be tightened once slipped over the lens. the one that does fit has about a .75mm thickness where as the others is 2-2.5mm
What lens is the thicker one for??
And can these be used both on the 35mm and the 50mm, or only on the 50mm?
Any help is appreciated!
The model numbers are 13351(Fits) and 13352X(Doesn't fit).
Cheers
Mike.
Cheers
Mike.
mtokue
..........Anyone???.........
