paulfish4570
1,2,3,4,5,6,7 or 8?
Recommended seller from FSU?
Thanks.
Thanks.
pschauss
I bought one a few years back. I don't remember which one, but it did not work. I now have a Sverdlovsk 4 which I use when not uising my VC-Meter. It measures either reflected or incident light and has a small view finder which allows it to be used as a spot meter.
As far as FSU sellers are concerned, I have had good luck with Alex-Photo and Kubanoid.
MV72
Marc VERRIERE
I've got a Leningrad-4 that works reliably used with my russian iron. Bought it from "cupog" on the bay. You can find one at "confdntart" too. I've been quite happy with what I bought from him so far. Maybe you can have a look.
Marc
Marc
jbielikowski
Jan Bielikowski
Svierdlovsk 4 is THE lightmeter, there is even export version for ragular AA battery afaik. I'm using it for at least 10 years and its perfect.
rxmd
May contain traces of nut
1,2,3,4,5,6,7 or 8?
Option 9: None of the above.
If you want an FSU lightmeter, get a Sverdlovsk-4. It uses a battery, but as it's not a selenium meter it gives much more reliable data.
paulfish4570
Thanks, guys. I'll check 'em out. A Gossen Pilot 2 would be OK, too ...
