Leningrad (help needed)
vanyagor
8:50 PM
Vancouver, BC Canada
I just started to test my Leningrad. Without film everything seemed fine. Without film I could get up to 18 "shots" at 1/250.
After I inserted film, and made couple of shots I'm not able to make several shots in a row. After each shot I have to turn the shutter knob again.
I might be missing smth. Can you help?
it's typical for the Leningrad that when it's gears get stiff and stuff it needs a CLA of gears, motor spring etc. I gave it to a repairman and it worked fine (had the same problem with two cameras).
Ivan
How tight have you wound the motor spring?
Have you tightened the central wheel under the take up spool to reconnect the clutch?
JonP said:
Ivan
Very tight for both
In fact the winding knob worked the same way as it would work on a fed 2 after several shots. I was able to wind it just a little bit (to the limit) and then make 1 shot. That's it. It seemed that smth was stuck.
I was not able to rewind film after I finished shooting and also film counter was not advancing as it was supposed to. To remove the film I had to unscrew the smaller wheel under take up spool the one in the center of the big wheel)
I think I have tightened the central wheel pretty hard
"Very tight" may be too tight on the winding spring!
The winding mechanism of a Leningrad is pretty simple: the winding spring exerts constant tension on the wind mechanism, which is restrained by a little catch until the shutter is released.
If you wind the spring too tightly, there may be too much friction to allow the catch to release.
More detail: This will be hard to explain unless you're looking at a Leningrad, but if you look up in the takeup chamber you'll see a shaft about where a normal camera would have its sprocket shaft, and at the top of it is a little flat spring-loaded lever that swings back and forth. This lever controls the action of the winding mechanism. On early Leningrads, the lever is loaded by a rather limp little hairspring; if the camera is wound too tight, this little spring won't have enough power to overcome the friction caused by the winding spring pulling against the catch. Later Leningrads have a much heavier hairspring on this little lever, and these seem to wind more reliably.
So, what you need to do is find out by experiment how much to wind the knob, and how much is too much. Tightening it until it feels really tight is likely to be MUCH too much! Try giving the knob about six turns; if it advances as it's supposed to, you can try a bit more until you exceed the limit. The amount of winding it will tolerate seems to vary considerably from one Leningrad to the next.
Incidentally, once you've found the proper number of turns for your camera, it may still hang up occasionally, and here's a trick that often will free it: turn the shutter speed dial (without lifting it) back against the spring tension about 1/4 turn, then release it and let it snap back under spring pressure. Often this will free the tension enough to let the film advance to the next frame.
