thawkins
I need a cap for an I22 lens. Where can I get one or what do other members do for a cap for this lens?
xayraa33
rangefinder user and fancier
Years ago I obtained a few bottle caps from the 3.8 litre jugs of Swish floor cleaner from a janitor and these worked fine as a lens cap for that lens.
shawn
I 3d printed a lens cap, rear cap and lens hood for my I22.
I used this: https://www.thingiverse.com/thing:400798
as the base for the cap and just resized it as needed to fit the I22.
Shawn
webOSUser
They are available at Fedka.com.
Found under Accessories for Body and Lens. It is listed as Lenscap, 36 mm, for Industar-22, -50, FED [36lenscap] $6.95 each.
http://fedka.com/catalog/product_info.php?cPath=49&products_id=564
I bought one and it fit my FED f3.5/50mm lens well enough.
He also has some Russian press on filters for the same lens in stock.
Steve
Steve
Ko.Fe.
Lenses 35/21 Gears 46/20
David Hughes
David Hughes
It's just a slip on 36mm lens cap but the problem is that that size also fits Leica lenses and the price is usually adjusted upwards...
Plastic caps. from bottles, usually fit nicely and can be bright red so you seldom forget to remove them and don't cry for long when you drop them and never find them or else tread on them...
Regards, David
Regards, David
