Lens cap for Nikkor 50/1.4 LTM
Vier14
6:22 AM
Dear all,
I've sadly lost the "Nicca" cap I had on my Nikkor 50/1.4 LTM.
It was slightly too loose.
I believe it was 43mm.
I've seen recently seen some 42mm "Nippon Kogaku" caps on ebay.
Do you what are they made for? Will they suit a 50mm/f1.4 LTM?
Thanks for your advice.
Best regards
Olivier
I will go out on a limb & guess that the 42mm lens caps are for the 5cm/2 Nikkor-H, which had a filter thread of 40.5mm (like the Zeiss 50/1.5 & 50/2 Sonnars).
Dear all,
Best regards
Olivier
Dear all,
Olivier
In regards to the 50mm/f1.4 LTM, the 42mm caps do not fit. I've tried :). The size that you is 46mm.
Check Grays of Westminster, in London. They stock a huge selection of new and vintage Nikon stuff. I found a lenscap there for my 1956 ltm 28mm W-Nikkor C.
