Lens CLA oil
nongfuspring
9:39 AM
Last night I degreased and regreased the helix on my industar 26. It made a huge improvement (it's amazing how much crap was in the lens), but it still has a slightly loose, rough, feel to the focussing which I can only put down to the manufacturing tolerances being not that great. I was wondering if the right choice in oil might help. I used a generic synthetic oil I think is probably used mostly for sewing machines that has a very fine almost watery consistency, and was wondering if it would be better to use something a little more viscous? What works for you guys?
I think that you should use silicone grease instead of oil. Oil just eases friction between surfaces, while some lubricant with higher viscosity such as grease would provide a tighter movement of parts against each other.
I've used synthetic wheel bearing grease on focusing helixes for some time now. Works quite well, especially for lenses that are a little loose. The only downside is that it will stiffen up somewhat in cold temperatures, so if you do a lot of outdoor shooting in winter this may be an issue.
Get that oil out of there -- not thick enough, so it'll not do the job over time. But more important, the oil will migrate to places you don't want. A light grease such as lithium grease will work well in all temperatures, and should last a long time.
The famed brian Sweeney used to use a synthetic vacuum pump grease, but i don't know where he bought it - makes the helical really smooth with just the right amount of friction.
Thanks guys, I'll redo the CLA and opt for the lithium grease for the time being. Will definitely also keep an eye out for that vacuum pump grease if I can.
I tried lithium grease at one point. It separated and spread like oil after a little while.
Not the cheapest solution but Micro-tools sells helical grease which may hold up better. I haven't had issues with it, though I haven't been able to pick up the lower viscosity(?)/lighter dampening one I'd prefer as they never seem to have it in stock. :\
Interesting about the lithium grease. I actually use some good quality Campagnolo grease for bicycles. Not exactly sure what's in it but it works very well -- just the right weight.
