J. Borger
I am using a Kaiser VPM 7005 enlarger. That is an enlarger with a Variable contrast head. I work in 6x6 B&W mainly.
I am fightin light fall off. I see (unacceptabel?) vignetting in all corners.
Even printing 6x6 negatives at 9 by 9 inch is a challenge, needing a lot of burning in of the corners ( about 3 x the total exposure time of the negative extra for the corners). I can not believe this is normal behaviour for this enlarger at this print sizes??
I checked the lamp (it is the correct hallogen lamp and it is fitted as it should), have the right lens (80mm) and lenspanel etc.
Any pointers or remedies?
Thanks in advance.
Thanks in advance.
