Light Leak Vooigtlander R3M
MDenton
8:39 AM
Last film processed from my R3M exhibits a light leak on the bottom of the frame - extending the full 36mm.
As I currently have another film in the camera I am unable to physically check the state of the seals,but would be interested in any feedback about light leak problems,if any, with this camera.
The R3M is my youngest film camera !
If it is the seals,any tips on replacing them ?
Thanks for the advice,however I think my tight fitting ever ready case should go some way towards achieving the same end.
Whilst light could leak in over a period of non use,it shouldn't be causing problems with a period of continuous shooting should it ?
The camera is always in the case,and this is the first time I have had this problem.
I hope it isn't coming from the front of the camera like the vertical shutter isn't completely closing. Is the light leak into the sockets too; I don't mean bleeding, is it all the way.
The plot thickens. I've just processed the second film- and no apparent light leaks !
Both films were shot in identical locations over a four day period.
As an additional check on the light seals with the final two exposures on the second film I put the camera face down with the back facing my bedside lamp for 10 minutes.
I wonder if the problem could be with the first film cassette - perhaps allowing light to leak in to the bottom of the film when removed from the camera awaiting processing ?
I shall ask the question on another forum I regularly visit.
