Other/Uncategorized Light lube, but not CLA?
Other Screw mount bodies/lenses
mike goldberg
The Peaceful Pacific
12:04 PM
If I remember correctly, several of our members have expertise in lubricants...
but I don't remember which members :rolleyes:
THE ISSUE:
When I get a camera from an FSU seller which is a bit stiff, I've been spraying an industrial "light oily contact spray," made in Israel... especially near to the advance knob mechanism. Then, I'm careful to wipe up any residue with a cloth lightly dampened with alcohol and water. There is very little oil in this stuff; I can feel that
on my fingers, and it works wonders.
QUESTION:
Is this an OK practice, and if not, what's an alternative?
Thanks, mike
Usually stuff like that is essentially a solvent, that can revitalise old grease for a while, but also relocates dirt inside, and inevitably dries out.
A proper solution would be to disassemble camera/lens, clean residue of old lubricant with a solvent, and apply a modern synthetic grease (for large/high torque moving parts) and, if necessary, synthetic watch oil (for axis of small gears, etc.).
Thanks, Eugene...
It appears then, if I have an FSU shooter that I like such as the Fed-2,
there is no substitute for a proper CLA. mike
Mike
If you can remove the baseplate or top plate from camera or the shutter module from a Kiev, then you dont have to do a Ruben and strip more, you can try camel hair brush and zippo fluid (petrol lighter fluid) brush on fluid to each bush and operate bush (if you can without parts flying about), apply more zippo, etc. you are trying to flow grease from bush.
Then you can try a light oil mini droplet on the end of a dentist tooth pick, I use PTFE liquid, for temperature stability, and lack of out gassing, the liquid will mix with grease residue (and any sand).
Taking small modules apart is the thing you should do - but life is too short for reassembly.
Noel
