I have one and it's an excellent lens. Pretty reasonably priced, too. Only issue is the frame lines but I learned a trick from Jaap that helps with that. When you mount the lens, rotate it all the way to the stop and it brings up the 90mm frame lines which are much closer to what the lens actually sees. You still have to do some guesstimation but not as much.
