twotroy
Do these exist? I've searched the web and on fleabay but not finding anywhere which has them available. I'm wondering if these exist -- or maybe is there an alternative way of fitting a 39mm filter to bay 3?
Reason why i want to use regular filters with a bay 3 adaptors:
--I have several excellent 39mm and 43mm B+W clear uv adaptors and metal lens hoods from other lenses. My goal was to see if I can use them on my 2.8C Rolleiflex using bay 3 adaptors. I only shoot color film so don't need colored filters.
My use case:
1: I would like to use a bay 3 to 43mm adaptor on the taking lens - tested this and it works
2: use a bay 3 to 39mm filter adaptor on the viewing lens - This way both filter adaptors will fit on the camera
just wanted to use what I have before I go thru the route of purchasing a whole set of standard bay 3 filters.
Thanks in advance
My use case:
Thanks in advance
xayraa33
rangefinder user and fancier
Get a Bay 3 to 43mm adapter and add a Kood brand stepping ring 43mm to 39mm
Both are available on Am@zon and Eb@y when in stock.
Beemermark
I have the bayonet III to 43mm adapter. Works great with 43mm filters which are relatively inexpensive. I think a reducing adapter to 39mm would vignette.
Dan Daniel
What do you want to put on the viewing lens? If it is a clear or UV filter for protection, you could simply buy a bay III filter and grind away the mount and glass as needed to make it fit around the lower filter.
