Leica LTM LTM dreaming - questions...
Ken Ford
Refuses to suffer fools
4:12 AM
One of the many inexpensive RFs I've been fooling around with these last few years is a Zorki-1. I always wanted a "real" Barnack camera, but could never justify the cost vs. benefit. The Zork let me play with the LTM concept with almost no cost.
A few years back when I first heard Tom A was tooling up for the Barnack Winder, I got this wild idea for a zone focus street shooting rig to complement my Bessa-T:
Leica Ic or If
Barnack Winder
C-V 25/4 with brightline
An offline email discussion with a friend today got me thinking about this again. Prices for Ic and If bodies are all over the place - what's realistic? How pricey are overhauls for I-series bodies? (I'd think they would be cheaper due to no RF/VF to fiddle with.) Am I nuts?
I was thinking of using my Leica IIIa as a base for my CV25lens, but found that the finder blocks my sight of the shutter speed dial enough so I can't see the speed. The Leica CL camera works well with this lens however.
The Barnack cameras that you mention may unfortunately be more expensive due to rarity and collectors.
The last one I saw was with a dealer in Bath and it was one of the more expensive Barnacks he had. It was a 1G with a 50/2.8 and was £850 ($1500) A IIIF was about £450 for the body.
Kim
Yes you end up counting notches to set the speeds.
But a Barnack just sort of fits your hand like nothing else. I have numerous M and R machines, but the 111f is a constant companion.
They are quirky though, like need all the finders and having to screw the lens on and off. Sit down or do it over some grass.
Tha 25 CV is very nice too.
I don't think I'd consider a Ig - too rare, too tall. The Ic and If have flatter top plates. I've seen a couple in the $400 range, which may be doable at some point.
The way I figure it a V-C 25 on the new M6 is overkill since it's not coupled. Why not have some fun with a little jewel instead?
This is moving away from your original thought, but how about the CV25 on a Leica M1 (classy) or hey, even the Bessa L! (high value)
11 or 111 as b or c?
Hello:
You are being correct in looking for the technical LTM models. However, a IIIb or c are common as a user and might be had for as little as $200-300 + CLA. My IIIb and a 25mm Skopar seem made for each other-best of luck.
yours
Frank
FrankS - a major part of the allure is Tom's Barnack Winder. An M1 would be sweet, but much larger; an L *would* work, but in that case why not just keep my T and Triggerwinder?
FPjohn - unfortunately, the Barnack Winder won't work on a prewar body. It needs to be a postwar c, f or g. Glad to hear you like your 25 - everything I've read about them is positive!
I got lucky and found a IIIa for $120 on the *bay. Described as EX condition, but I will see when I get it...
I too started with the zorki and am now moving to the real thing.
ferider said:
Also, consider a Barnack + CV 28/3.5 + Minifinder.
I found this a great combo. A little less wide but may be OK ?
Roland.
This is the route I went and it works great. I love the 28mm focal length. I have the 25/4 on an L, and the difference between the two is focal lengths is more than I expected, but I'm using the 28 on the iiig more now. With the minifinder, it is a great little pocketable package.
I'm also considering a trigger winder for it, but the TA winder is substantially bigger than the leicavit, so I am holding out for the leicavit.
Roland.
Interesting idea, Roland. That would be a lot more pocketable.
I just looked at Gandy's VF page, and either the Minifinder or the High Point would be a good choice. It sounds like the High Point may be a little quicker to use.
I'm a little concerned about the zone-focusability of the C-V 28 vs. the 25. I always liked the idea of the click-stopped focus on the 25.
I wonder if C-V will ever adapt the Minifinder or High Point package for a 25mm FOV?
The 28 has plenty depth of field for zone focusing stopped down a little, but psychologically I feel compelled to use the rangefinder just becuse it is coupled. Funny...
I love the click stops on the 25 (that was the main reason to buy it for me), but the depth of field is so huge that they are almost not necessary. Hyperfocal covers it most of the time.
i too am a fan of the 28/3.5 on ltm bodies. i've recently aquired the cv 21/4 and am looking forward to seeing how it feels/looks.
I acquired my IIIa on a famous auction site for $129, and it is perfect in every way. I've run about a dozen rolls of film through it so far in many situations and have had no problems. The key is you just have to be patient, unless money is no object. It took me about a month to find a good example at a price I was willing to pay. A little luck doesn't hurt either, but there are so many user II,III, IIIa, and IIIc models for sale that luck is on your side if you are careful.
Now, let's not get into how much I've spent on lenses, finders, strap, lens covers, etc......
I wish I could say the same about Ic and If models! The ones I'm seeing around aren't exactly cheap.
Since you already have experience using the Zorki 1, consider a Leica II more refined plus the roller RF sensor does not limit your choice of LTM lenses. Cheaper than an uncoupled Barnack and hardly bigger with the option of RF focusing. In the long run there's less to go wrong w/o the slow speed which you don't seem to require.
Joseph
A friend of mine recently bought a mint Zorki 1. The exterior was beautiful. It came with new shutter curtains and the thing was as quiet and smooth as my IIIc. Maybe even a little quieter. A Zorki I with new curtains and a CLA is nothing to be embarassed about. Sweet little things. Oleg will make your Zorki like new and will work on any Barnack Leicas, too. The CLA on my IIIc with new shutter curtains was $60. It varies from camera to camera. The Zorki CLA usually runs under $40. Well worth it!
