Luba the Russian Fell on her Knob. :(
ibcrewin
Ah looky looky
10:01 AM
I dropped my lubitel 2 on the rewind knob side and it looks like the bakelite broke off at the knob :bang:. What can i use to cement this bad boy back into place and keep it light tight? Looks repairable but I think it's going to need to be built up to keep it from leaking light.
If it really is the original Bakelite I have a dim and distant memory that cellulose thinners is a solvent. So it may be possible to “weld” it with that, anybody know for sure??
I have had good luck with the two part glue used to fix the rear view mirror to glass, available in autopart stores. I have not used on Bakelite, however. Epoxy putty is good for filling holes, etc.
Pretty much your only hope is epoxy putty. I can't think of anything else that would work and that would also be impervious to light.
I don't think there is such a thing as a solvent for bakelite. Bakelite is a cross-linked polymer of phenol and formaldehyde. It's just one molecule. There are no polymer chain ends to be attacked and it's resistant to all solvents.
