Lucky it's still under warranty! M8 sensor glitch!
noimmunity
scratch my niche
11:23 AM
I first noticed it on high ISO shots, a hideous vertical line (not the red line of some earlier ill repute):
At ISO 2500
Here is a 100% crop at ISO 640
Once I started looking I found the line in most every shot, at any ISO.
I was sure that I did not see this problem when I first purchased the camera about a year ago from Robert White in the UK.
Examination of photos in my archive shows that it developed sometime after I moved to Shanghai last fall. I didn't notice the problem because I didn't have a proper computer for most of the time I was there, and only returned to postprocessing very recently.
My M8 was purchased in the UK under the terms of the 2 year passport warranty, which Leica UK says they will stand by. Looks to me like this camera has to make the pilgramage back to Solms for a sensor replacement.
Hey mods, is it true that threads in this "reported problems" section don't show up in the New Posts list? (edit: the thread apparently only appears in the New Posts list after a response to the OP has been posted).
It showed up in my "New Posts", noimmunity, even before you posted a response.
good to know, thanks!
Looks like you've got two of them... I see one from the guitar's head to the guy's neck as well!
I neglected to specify that those are two different photos (thought the ISO difference would make that clear, but then again, saying one was a crop was misleading for sure), and the lines in each photo (as in all the others) occurs in exactly the same spot. Seems to be related to a dead pixel.
Has anyone had this problem of a line developing with use?
...and I thought the only problem was banding at high ISOs, sheesh!
What are the first 3 digits of the SN? Should give an indication of the batch number.
My oldest Digital camera just turned 18. Also has a Kodak Sensor, a KAF-1600. It has picked up 3 Hot Pixels, and is a 1.6MPixel CCD.
Mine is the same batch, I picked it up second-hand still under warranty. It was new as of 10/2009. I do keep an eye on it, so far ISO 2500 shots are very clean.
