M Lens Ser# That Can Be Coded
POINT OF VIEW
6:44 AM
6-bit coding is not possible on some lens. For the modification it is necessary to disassemble the bayonet and the spiral. Some lens, like Summilux-M 1,4/35, pre Serial # 3636, bayonet and spiral are one component and it is not possible to separate them.
Below is a list of lenses currently available that can be coded.
Name color Cat.# Delivered Starting#
Elmarit-M 21 mm f/2.8 ASPH Black 11135 1997 3796510
Elmarit-M24 mm f/2.8 ASPH Black 11878 1996 3737xxx
Summicron-M 28 mm f/2 ASPH Black 11604 2000 3889xxx
Tri-Elmar-M 1:4/28-35-50mm f/4
ASPH Black 11625 2000 3891871
Summilux-M 35mm f/1.4 ASPH Black 11874 1994 3636xxx
Summicron-M 35mm f/2 ASPH Black 11879 1996 3767xxx
Summicron-M 35mm f/2 ASPH Silver 11882 1996 3767xxx
Noctilux-M 50 mm f/1.0 Black 11822 1994 3367xxx
Summilux-M 50mm f/1.4 ASPH Black 11891 2004 Current
Summilux-M 50mm f/1.4 ASPH Silver 11892 2006 Current
Summicron-M 50mm f/2 Black 11826 1994 3669xxx
Summicron-M 50mm f/2 Silver 11816 1994 3669xxx
Elmar-M 50mm f/2.8 Black 11831 1995 3668xxx
Summilux-M 75mm f/1.4 Black 11810 1998 Current
Apo-Summicron-M 75mm f/2 ASPH Black 11637 2005 Current
Apo-Summicron-M 90 mm f/2 ASPH Black 11884 1998 Current
Elmarit-M 90mm f/2.8 Black 11807 1990 Current
Macro-Elmar-M 90mm f/4 Black 11633 2002 Current
Macro-Elmar-M 90mm f/4 Silver 11634 2002 Current
Macro-Adapter M Black 14409 2002 Current
Below is a list of discontinued lenses that can be coded.
Name Color Cat.# Delivered Starting#
Elmarit-M 21 mm f/2.8 Black 11134 1980-1997 2993701
Elmarit-M21 mm f/2.8 ASPH Silver 11897 1997-2004 3796xxx
Elmarit-M 24 mm f/2.8 ASPH Silver 11898 1996-2005 3737xxx
Elmarit-M 28 mm f/2.8 Black 11804 1979-1992 2977551
Elmarit-M 28 mm f/2.8 Black 11809 1992-2005 3585865
Tri-Elmar-M 28-35-50mm f/4 ASPH Black 11890 1998-2000 3753126
Tri-Elmar-M 28-35-50mm f/4 ASPH Silver 11894 1999-2000 3753126
Summilux-M 35mm f/1.4 ASPH Silver 11883 1994-2004 3636xxx
Summicron-M 35mm f/2 Black 11310 1979-1996 2974251
Summicron-M 35 mm f/2 Silver 11311 1993-1996 3610xxx
Noctilux-M 50 mm f/1.0 Black 11821 1975-1994 2749xxx
Summilux-M 50mm f/1.4 Black 11868 1992-2004 3675xxx
Summilux-M 50mm f/1.4 Silver 11856 1992-2004 3675xxx
Summicron-M 50mm f/2 Black 11817 1969-1979 2269xxx
Summicron-M 50mm f/2 Black 11819 1979-1994 2915xxx
Summicron-M 50mm f/2 Silver 11825 1992-1994 2915xxx
Summilux-M 75mm f/1.4 Black 11814 1980-1982 3063xxx
Summilux-M 75mm f/1.4 Black 11815 1982-1998 3223xxx
Summicron-M 90mm f/2 Black 11136 1980-1989 3163xxx
Summicron-M 90mm f/2 Silver 11137 1993-1989 3643xxx
Apo-Summicron-M 90mm f/2 ASPH Silver 11885 2002-2004 3815xxx
Tele-Elmarit-M 90mm f/2.8 Black 11800 1973-1989 2585xxx
Elmarit-M 90mm f/2.8 Silver 11808 1997-2004 3556xxx
Elmarit-M 135mm f/2.8 Black 11829 1963-1997 2289xxx
