m+m39 lens walk around
orendanger
8:58 PM
i just got my first Digital Rangefinder (R-d1) and have on it and industar 50 mmf2.8 i love the lens BUT its a bit bulky is there a lens that is more "man bag-able"? kinda like the olympus ep-1 with 17mm and vf1, also has anyone bought an "ugly" rated lens on KEH?
Last question, I really like the industar and the story it has any other intresting lenses? i was thinking canon 50 f1.8 at some point..
P.S.
i want to thank everyone on here you have been a great help!
Where are numerous threads on-line called "KEH rating". Google it. Personally, I'd rather buy something I could see in full details, which KEH is not providing.
FED-10 most likely going to be fully collapsible. They are cheap on e-bay.
You'll get suggestions.
Lots of lenses with interesting history. Some more interesting than others. Pick one and ask around here on RFF.
The Canon 50/1.8 can be an outstanding lens. It will be a bit larger than the I-61 (which I assume you have based on the f/2.8). Others will agree; pay attention to possible haze in the Canon 50/1.8, its a known issue and you definitely don't want it. It sometimes can't be cleaned off. Most other lenses with haze can be successfully cleaned.
Other 50mm lenses that are smaller than I-61 are mostly going to be collapsible. I don't know about collapsing lenses on an RD-1 so definitely get guidance from others here who have the RD-1. In general though, I don't think you'll find a 50mm lens that's not collapsible and appreciably shorter than the I-61. Its just the nature of the lens design. Now, if you want to use a shorter focal length, there are many options of wide angle lenses with shorter physical dimensions.
Just some of the possibilities in 50mm-ish that are fairly compact:
1. Leica Elmar 50/3.5 (collapsible)
2. Industar-22 50/3.5 (collapsible)
3. First version summicron 50/2 (collapsible)
4. Leica summitar 50/2 (collapsible)
5. Cosina-Voigtlander Heliar 50/3.5 (collapsible)
6. Cosina-Voigtlander Color Skopar 50/2.5
7. Canon 50/1.9 (collapsible)
8. Canon 50/3.5 (collapsible)
9. Minolta Super Rokkor 45/2.8
10. Leica Summarit 50/2.5 (recent model)
11. Jupiter 8 50/2 (no more compact than the I-61)
12. Fed 50 or I-10 (collapsible, not much different, if at all, from the I-22)
13. Leica Summar 50/2 (collapsible)
14. Many others. There are many more 50's out there but most are not collapsible and some are substantially larger than the I-61. Also, price varies quite a bit. You can pay as little as $20 for some of the FSU options, or upwards of $10,000 for a Nokton.
You might also want to specify a budget range to help narrow the suggestions you'll receive here.
budget.. no more than a new color skopar 25 F4 420$ i think and used is about 100$ less, doesnt have to be 50mm size is more important 🙂 even a noctolus doesnt help if its at home
An IL-61 is aluminum, and will be lighter than most of the other lenses. It's fairly small. If you want something "less bulky" than that, there's not much else, except collapsible lenses. Which may not collapse on a digital. All of the M39 lenses from Europe and Japan are usually heavy brass. The Soviet stuff is light aluminum.
