ericdan
The door on the back that flips open when you take the base plate off has a little too much play. It shifts left and right. It's still light tight but I would like to fix this somehow.
The little spring loaded pin that lets you take it off and mount it is probably the issue. I don't know if that can be fixed.
I thought of two other options.
1. Put something in the holes that the pins are fitted into. What should I use for this? Glue?
2. Find a tiny washer that will take care of the wiggle room. I looked for pins in my local hardware store but couldn't find anything even close to the size I need. Maybe a watch repair shop would have something small enough?
Does anyone else have this issue? Has anyone else managed to fix this another way?
Thanks!
Thanks!
