M5 Film reminder question
Charles D. Orze
7:44 AM
I've been trying to figure out the meaning of the symbols on my M5 film reminder dial (the one on the back door). Obviously we have shutter and f-stop calculator, and then something that looks like a bulb (flash/Tungsten?). Also a sun (daylight?) the letters "NE" and a white triangle. The user manual pdf I have is silent on these. Any clues?
Thanks,
Charlie
I always assumed: *Bulb* means tungsten balanced slide film, *Sun* means daylight balanced slide film, *white triangle* means B&W film, and *NE* means color negative film. But I've been known to be wrong.
Chris
I suppose one could assign any meaning that one could remember.
The secret decoder function is only revealed to the True Faithful after demonstrating the M5 handshake.
That's what I try to do. But the next time I pick up the camera, I usually forget. I have resorted to wedging the the flap from the film box in between the case and the camera, when using a case that is.
I was about to suggest what Wayne has said already. Then I would have pointed to the danger which cpborello has identified.
Not only is remembering the symbol/film assignment a problem, the biggest problem for me is remembering to set the dial when I load film. One more point for "one camera, one lens, one film".
