M5 take up help!
Steinberg2010
1:55 PM
I got to the end of the roll in my M5 and the film detached itself from the canister (I had bulk loaded - obviously not very well). I managed to eventually get the film out by removing the take up spool. However I then noticed that the central shaft dangles out of the spool - is this normal?
Thanks for all your help!
~S
It's normal. It's there so you have something to grab to pull the take up spool out. Mine is stiff and doesn't fall down, much. The manual refers to this. It recommends removal and reinsertion so the take up tines are oriented as per the shutter cover diagram. I've still not got the hang of reliably loading the M5.
Interesting! I've never taken mine out a single time. Maybe I should being as I just had my first mis-load the other night :)
