M6 frame lines with Leitz M3/ 28-50 LTM-M adapter
rardinger
7:43 PM
Ran into a couple of LTM-M adapters I had not seen before. They are marked:
Leitz M2 50, M3 28-50
and
E. Leitz M2 50, M3 21-50
I know in M6 (0.72 finder) terms the current LTM adapter that brings up the 50mm frame lines is marked 50/75 (and then 28/90 for that pair of frame lines and 35/135 for that pair). I have used an older adaptor that I think was just marked M3 5 cm (may also have had an M2 reference)
My question is -Am I right to assume that the M2 50/M3 28-50 and the M2 50/M3 21-50 would activate the 50mm frame lines on an M2 or M3 AND will activate the 50/75 lines on an M6?
I wanted to use the adaptor with an LTM 50mm lens on an M6 (physically do not have either the adapter or lens in front of me but gambled and bought the adapter at a good price and want to order the lens).
Thanks
Robert
That is correct.
