M8 and high ISO, questions
eleskin
11:30 AM
Hi everyone!
On one of the posts I have read that to get good higher ISO, it is best to set the ISO to 160 and set the EV to -3. I have tried this and try my eye it does seem to eliminate the noise and banding issues I have seen in the past. So how many of you have used this method and do you like the results? Samples and input would be greatly appreciated!
It does eliminate banding and minimizes noise because
  • the M8 uses a two-stage analog DC amplifier to increase the sensor signal levels when ISO is above base ISO; at ISO 160 the low-gain stage is used; at higher ISOs (800 if memory serves) the camera switches to its high-gain amplifier
  • with this method the part of the signal responsible for the banding (a.k.a. the artifacts) is not amplified to the point where it is digitized; similarly the read noise level is lower as well
However this useful technique is limited to a three stop 'push'.
In general newer technologies have lower artifact levels which only become digitized at much higher ISO amplifications.
At some point the signal from all sensors can be amplified to a level where artifact components become digitized. This is the reason some brands switch to digital multiplication to increase the signal (and noise levels) or a hybrid of digital and electronic methods at higher ISO settings.
The last 2 pics were 100% screen grabbed with shadows pushed to +60. Zero sharpening and all other settings were left to zero.
Cheers
I'm picking up an M8 tomorrow so it will be cool to give this a try.
When I had one before I wasn't aware of the ISO trick, but really like the results shown here.
Thanks for posting them David.
Nice to hear. Funny we read up on things like this before even owning an M8.
Sidenote:
I was on a hunt for a 50mm Summicron but I figured I'd sell my X100T and get an M8.2, problem solved. Haven't acquired the M8.2 though.
You are welcome Ben, nice Blog by the way. Enjoy your M8 :)
M8/8.2 is no high ISO Monster for sure (There are other cameras for that) . But the base ISO is really good.
Here's an old pic, one of my fav. Cheers!
50Summilux/M8 by David Lam, on Flickr
I've also noticed for my M8 images in Lightroom that shooting at iso 640 -1EV and boosting exposure post gives me great results. This improvement was even more pronounced after upgrading from earlier versions of Lightroom.
Anyhow, I will have to give the 3 stops method a try.
