M8 + IR Filter Profiles for Lightroom 2??
DrDick
4:26 PM
UK
I mainly use either a Tri-Elmar or WA Tri-Elmar on my M8. The trouble with frequent lens changes is not remembering to tell the M8 which focal length you have set on the WA TE. I almost always use 16mm - but the camera defaults to 18mm. I find this results in Cyan corners to shots. I can't find a way of getting the M8 to default to 16mm rather than 18mm. ?Could a future firmware upgrade offer this. Is it possible to get individual M8 correction profiles that I can load into Lightroom 2 so I can choose them manually when editing raw DNG files. Does anyone have a profile for correcting a miss-set 18mm to 16mm shot. Incidently choosing Adobe standard as the profile in lightroom produces a better (less cyan corners) result than ACR 4.6 the default for lightroom. Any answers please! :bang:
There isn't an effective way to correct for that in LR. CornerFix can correct for cyan or red drift due to a mis-set lens, but you will have to generate a profile by re-creating the "wrong" configuration, photographing a grey card or blank wall, and generating a profile from that.
Sandy
