M8 picture counter strange behaviour
pstevenin
10:50 AM
I am a happy M8 (1.107) owner since two weeks that deliver stunning images but the image counter behavior is quite weird.
On the continuous mode, it increments quite normally and when I switch the SD card, it starts again from a previous number (the first time I noticed that, it starded from 0001 again, and yesterday it started from something like 0058) .
The counter sounds working well when I use only the same card. Does somebody notice that?
Any clues?
Best regards
Philippe.
I know about this same behavior with other cameras. I think you must enter the setup area and change the counting method. Hope this helps
pstevenin said:
Any clues?
Best regards
Philippe.
This happened to me once when I put in a brandnew, not previously formatted, card. Always format your card when you put it in, new or old card, before taking pictures!
Here is the cure: copied from the Leica user Forum:
Best regards
Sander
Here is a procedure that will allow you change to anything you want:
1. Set the Picture Number in the menu to "Standard".
2. Format the SD card in camera.
3. Reset the File Number in the menu. It actually says “Reset fold. No”, that is the one you want.
4. Set Picture Number back to "Continuous"
5. Take one image
6. Shut off camera, remove SD card and place in card reader attached to a computer.
7. Access the image in your Finder or Explorer (Mac or PC); rename the image number to whatever file number/image number you want. I would suggest Lyyyxxxx, with "y" being your preferred folder number (See Note Below) and "x" being the frame number you want to start with. (You are making these changes to the file name on the card in the card reader.)
NOTE
If you want to change the first or second digit of the L100 (Lyyy above) in the file name, like to L200 or 120 or 220, then you have to change the folder name also.
The directory/folder structure on the card when in a card reader is [Drive Letter]:\DCIM\100LEICA\. You need to change the 100LEICA to whatever you want the file number to start with. Like if you want it to be L200xxxx then you need to rename that folder to 200LEICA. If you want L120 then you need to change that folder name to 120LEICA. It would look like this [Drive Letter]:\DCIM\120 or 200LEICA.
8. Properly remove card from card reader and return to camera.
9. Turn the camera on and press "Play". The file will now display with newly renamed folder and file number. (Use "Info" to see this data.)
10. Expose another image to confirm and check file numbers.
11. Format SD card, and you are good to go from that point on.
M8 format 2GB Sandisk Extreme to FAT32!
The Format sequence works. Thanks a lot.
But I notice one thing: M8 formats 2GB Sandisk Extreme to FAT32 (instead of FAT16).
And when I insert another SD card formated as FAT16, the counter drops to 0001 again.
Re-insert the FAT32 card, and the counter resumes to the original higher number!
Looks like M8 prefers FAT32, even if the card is less than 2GB.
(Too bad - this means the FAT32 2GB card may not be usuable on other cameras, like Ricoh GX100, which uses FAT32 only for 4GB card or above.)
Normal cameras: FAT16 for 2GB or below, FAT32 for above
Leica M8: FAT32 for all
I hope the next firmware release may adress this anomaly.
I have given up on the internal numbers of the camera. I use ImageIngester, which assigns individual numbers to the imports and then puts them in separate folders per day. Very practical.
