R
rpsawin
Guest
It appears I need to clean the sensor in my M8. Do any of you have any tips or techniques you can share? Also, which supplies did you use?
Thanks in advance,
Bob
Thanks in advance,
Bob
Thanks in advance,
Bob
Don't over think it ... these things are nowhere as delicate as we're led to believe.
I do recommend wet cleaning though as the two times I've had to clean mine it had grease spots on it that dry cleaning just smears.
I use the Lens pen www.bhphotovideo.com/c/product/673515-REG/Sunpak_SP_LP1_SP_LP1_Lens_Pen.html
Cost $8.95 dry method. I have used this on My canon and on my M8 . works very easy and not all wet and swabbing Ect. The wet method is an over kill. The sensor is not that delicate, scrub it.
