_goodtimez
Hi All,
I am interested to know if any of you has removed the Top Cover from an M8, or if you have a link to show how to do this.
I do have the capability to make my own tools for that (like the special pliers for the M6 top removal).
I will receive soon the dunken M8 from my sister and I would just like to start with the top off, to see if there is any corrosion at that level and eventually clean the inside of the VF glass.
Thanks
Thanks
rlouzan
Hope It Helps
http://www.l-camera-forum.com/leica-forum/leica-m8-forum/21331-anatomy-leica-m8.html
WTB: 35mm f3.5 W Komura, W Acall Kyoei, Telesar or Accura ltm lens.
Please send PM with details
_goodtimez
Thanks I already looked carefully but he does not indicate. Hmmm I'm really wondering.
Jeicob
Amateur
http://www.l-camera-forum.com/leica-forum/leica-m8-forum/73166-how-unscrew-viewfinder-lense-if-its.html
To remove the top, you'll need a Phillips P000 screwdriver and a long P00 one, 75mm.
1. Remove the base, battery and memory card.
2. Use the P000 screwdriver to remove the 5 screws; these are tight and you should press into the screw when first loosening them to stop the head slipping.
3. Remove the plastic plate; look inside the battery compartment and remove the screw nearest the end of the camera using the P00 screwdriver, this screw will come out; you'll need the tweezers to put it back.
4. At the other end, look for the hole in the motor baseplate. Insert the screwdriver and feel for the screwhead; this screw is captive and will not come out.
5. Ground yourself to a water pipe or electrical earth to avoid any static discharge
5. Ease the top off and release the flex-print by lifting the plastic latches and gently pulling it out; avoid touching any electrical contacts.
You can then clean up, avoid at all costs getting your finger prints on the inside of the rangefinder windows and the rangefinder components - think about wearing silicone gloves.
_goodtimez
So cool. Many thanks I appreciate.
