M9 Save user profile problem
laica
1:00 AM
I am having problems with saving user profiles.
Factory settings is set on sRGB. Can't change this in menu.
I have to go to snapshot settings, press set en leave snapshot setting to be able to change this into RBG.
Then I save it as a new profile say under profile 1.
If I go back to set button , the profile 1 is not showing, instead it is showing "-"
I have firmware 1.002
Can somebody confirm this problem ?
Saving other changes give me the same problem. 😕
Other example:
Reset back to factory setting.
Choose menu: not able to change from sRGB to RGB.
Press set: change user profile to snapshot mode
Press set again: exit snapshot mode
Press menu: now you can change the color space to RBG.
Save these settings as Profile 1.
Press set: profile 1 is selected and all settings are OK.
Turn camera off and on.
Press set: not able to select Profile 1, displays "set user profile: - "
Press menu: color space is back to sRBG
I was not paying attention at all :bang:
I tried to change the color mode while I shoot DNG.
That's the reason why the user profile was not saved.
In order to avoid confusion this option should be locked when strictly DNG is set.
