M9 +wide angle lens colour shift
IanBiggar
6:59 AM
Anyone point me in the direction of tutorials on how to correct the colour shift and vignetting using an M9 and C/V 15mm M mount lens. I can't seem to access Jeff Hapeman's tutorials.
Thanks in advance.
Ian
Install Cornerfix.
I'm not a Lightroom user but I hear lens color fringing can be eliminated through a profile in LR.
Good luck!
Phil Forrest
M9 wide angle colour correction
Thanks Phil - I've already downloaded CornerFix- and- I can find all sorts of links to a tutorial on CornerFix by someone called Jeff Hapeman but when I click on them it's a dead end.
Ian
Dear Ian,
For my VM 15mm Super wide heliar, I
1. Set the lens as uncoded on the M9:
1. Shot a picture of a white wall, 1 stop overexposed, f8.
2. Saved this as the profile in Cornerfix.
Now, I use the VM 15mm in uncoded mode all the time and correct the magenta cast/vignetting in Cornerfix using the above profile. If you want the above lens profile, PM me with your email and I'll send it.
Monz
M9 and W/A
M9 and W/A
Monz - thanks for that - will be trying that and looking closely at the Cornerfix site.
Albertospa - will try that as well tho' most people say the 11134 21mm setting is the one to go for. Thanks.
Still don't know where all the Jeff Hapeman (DigitalHapeman) stuff went. Comes up as :"URL not found 404 error" etc. I remember reading it awhile ago and thinking it was pretty useful stuff.
Ah well - thanks guys.
Ian
