mamiya 6/7 + 50mm - how much should i pay?
meandihagee
11:00 PM
also any tips on the problems a mamiya 6 could have opposed to to the mamiya 7? i'm torn between the two.
the metering is very important for me. as i read on this forum there are samples with problems with the meter. which should i go with?
I went with the 6. cooler format, collapsing feature and it feels better built overall. I've never had any of those problems you mentioned.
I paid 1000€ for body + 50mm + 150mm, which is quite a good price I thought, but I don't know if that reflects the current market value.
With both cameras:
- you need to use the metering - it is not your SLRs matrix TTL
- you need to be careful focusing the 150 lenses, RF precision is on the limit there
- you get only +/- half stop precision metering in manual mode (you can set ANY aperture of course, just the confirmation in the viewfinder is limited in precision)
- you get perfect lens performance (sharpness, contrast)
Get the 6 / 6 MF if:
- you like it square
- you like it more compact (collapsible lens mount make a sizable difference)
- you find one with film winding in good order (nearly impossible to get repaired, Mamiya does not supply parts anymore)
- you prefer wider-area meter (about the 75 mm lens frame-line)
- you can not afford the 7
Get 7 / 7 II if:
- you like it rectangular
- you are wide lens junkie
- do not care about the size of the camera when stored in the bag.
- want to be able to get the camera repaired if something goes wrong.
- you prefer spot meter (about the focusing spot size, not necessarily perfectly aligned with it)
- can afford it
If you do not need long lenses and 6x45 would be fine
- Get bronica RF645 with 45 & 65 lenses - cheaper than Mamiya 6 and should be even easier to use.
I got the 6 with all 3 lenses - I paid together about 1500 €. The camera is used but the film winding mechanism was exchanged relatively recently so I have some confidence for the years to come, I hope.
7 are not that expensive - much less than 7 II, but you will pay more for the lenses than for the 6.
6MF with 75 lens may cost as much as 7 with 80, but you will pay more for the other lenses.
Now that I have actually read the title:
guess that for 6/7 + 50 you will be buying the body and lens separately the price in Europe would be around:
6 + 50: 900 - 1100 €
7 + 50: 1100 - 1300 €
If you are in US, than just convert the € to $. My impression was that there were no significant differences.
If I were you I would just watch eBay for a month or two to get an idea.
thanks for the quick replies.
do you rely 100% on your meter or you use a hand-held one?
if the meter is so-so i would like to know because this is the main reason for getting this camera. i will be shooting this in a rather hostile area and i have to be quick on the draw...
Ive just bought the mamiya 6, with the standard + 150mm lens, but the 50 is on my to buy list.
Regarding the metering, defiantly shoot with the camera before doing anything important, it took me a couple of rolls of colour neg to get them exposing how i like, mainly in backlit/large sky area shots, i find i've got +1.5 stops dialled in on the exp compensation pretty much permanently now. after doing this however ive yet to use anything but the in built meter
I had a very good deal. I bought the 6 with the three lenses for 600 Euro's.
I use the meter all the time. Works good for me.
Michiel Fokkema
600 euros for the Mamiya 6 and three lenses sounds like a deal of the century for me. I bought the mamiya 7 and I am still learning the meter, but I think this is my favorate camara. I still like the mamiya 6 as well. It is a difficult choice but I think that Matus sumed it up very nicely.
I've used two different Mamiya 6 bodies with 75mm and 50mm lenses(early bodies - with symbols for AE and AEL). I found I needed to set the exposure compensation to +2/3 to get the metering agreeing consistently with my handheld meter.
Have others found the same?
I like the 6 for compactness. The 75mm lens is a joy. Paid $1100 for camera and 75mm in almost mint condition.
Average US prices for 7 gear:
7 body: $400-800
7II body: $550-1000
7 50mm lens: $850-950
(These are ebay prices for stuff in Exc++/NM condition.)
-Ed
Me too. Use the compensation at + 1 works for me. It seems that the meter in many surroundings has the tendency to be a little off. But compensation is easy and works.
