Mamiya 6 metering recommendations
hausen
7:12 PM
Hello all,
I have recently purchased Mamiya 6 with 75mm and am awaiting delivery of 50/150 lens early nexy week. Love everything about it so far except everything seems to be under exposed. Have shot 2 rolls of Fuji Acros 100 and 1 Ilford XP2 to try it out. Am getting back into film again after being on the dark side for 7 years or so.
Have looked extensively through web and owners are either 100% satisfied with the meter or like me think their body underexposes by about up to 1 stop. Have seen a number of recommedations, +1 ev permanantly, cover meter with your hand, wear a cap so the meter is covered from the sun or use an external spot meter. We are in winter here in NZ so there is not a lot of direct sun. Only issue I have with using external meter is portability but will if I have too. What do other owners think? Thanks in advance for any thoughts.
Dave
I had two Mamiya 6 bodies, did a big commission with this camera back in the mid 90s, sold one body around a year ago since I use the system much less now.
Best I can figure the meter is biased for transparency film and negative film will always seem underexposed. I think everyone has to find their own solution. You can, for instance, get close and meter the shadows, then step back and take the picture. I never use "A", only manual exposure.
I don't know what ISO you shot the XP2 at, but it's a film that needs a lot of exposure and is easy to underexpose it. I don't like it much but I have had beter luck rating it at 200 or even 100.
I have owned two 6MF cameras and have never had much of a problem with the meter. I think it is true that it can be easily thrown out by an area of particularly bright light in the image, but when this occurs, for example with a washed out sky, I simply tilt the camera down and exclude all or some of it depending on how much I think it is affecting things. Admittedly I have only ever shot neg with my M6MF's, HP5 in the past which I rated at 200ASA and currently XP2 which I use at 200ASA when there is enough light going to 400 when things get a bit iffy. I realise that this sort of slap dash approach to exposure will make people wince but it works for me with neg.
I would strongly recommend finding a way of getting the built in meter to work for you. I just sold a Fuji 6x9, with which I was using a hotshoe mounted Voigtlander meter, to get my second 6MF. Going back to built in metering is a joy, more time with my eye against the viewfinder and less time faffing about.
I think it is true that it can be easily thrown out by an area of particularly bright light in the image, but when this occurs, for example with a washed out sky, I simply tilt the camera down and exclude all or some of it depending on how much I think it is affecting things. .
Yeah, that works.
I routinely shade the meter with my left hand as it is very prone to underexposing if there's a bright sky. This can often make a one stop difference to the reading. Otherwise I find the meter pretty accurate.
I'm new to MF and have owned a Mamiya 6MF for almost three months. I followed some of the suggestions posted on the forum and found the Mamiya 6 (M6) to be well suited to be utilized like a Leica M7 using AEL mode.
I keep my M6 permanantly set in AEL mode where the shutter is stepless like on my Nikon F3's. I tend to meter off my arm or back of my hand because my skin tone is the same as a grey card. The only time I messed up was when I shot indoors, and I was quick to be lazy. There was not enough light, and I suffered bad exposures due to operator error.
If you are fair skinned, white just happens to be two stops off a grey card so you can use the exposure compensation to read your skin tone as a grey card. You will find that you will have very consistent negs.
Overall the M6 is a very fast shooter. Also know with the 50/4.0 that the metering has a center weighting where the 75/3.5 just averages.
The only bad thing about my M6 is that it consumes a lot of film. For me, with the 50/4.0 it is the perfect MF street shooter and that can rapidly get very expensive. I just wish I had an unlimited supply of Tri-X 320 in 220.
Cal
+1.
I forgot to mention this. I believe ambient light enters the VF adding to the measured exposure, especially from above. Manual settings seem to be coarser. AEL is the way to go.
Cal
Thanks for all the responses. Have tried the cap and the hand trick over the weekend and processed film last night. A definite improvement. Very much anything with a light source in front of the camera causes problems. Note to self. Thanks again.
I always just set the ISO to one stop lower than what I normally rate a film at. So for instance, I set the dial for FP4 to 50, or Tri-x to 200. I find the meter does tend to underexpose by 1 stop. I find that changing the ISO dial a better solution than permanently setting +1 on the compensation dial because I like to use the compensation dial for filters.
Well, no personal experience (yet, ,my Mamiya 6 should arrive in about 2 weeks), but especially on overcast day it may make sense to point the camera for a reference. I used to do it this way with my Digisix lightmeter which apart from incident metering offers also reflective metering within a cone of some 30 degrees.
