Mamiya 7 43 mm lens and pano adapter
mmcguire
5:04 AM
I enjoy using the 35 mm panoramic adapter with the 65 mm lens on my Mamiya 7. How would the pano adapter work with the 43 mm lens? Does the view finder have a format for an panoramic view? Mike
The viewfinder has a couple of grid markings in it, but I am not srue that they signifiy where the panaramic mask is. I am sure that you could do a test roll and figure it out rather quickly. It is a great lens though. I recommend it highly. It is more useful than a normal 21mm equivalent lens since the distortion is so low and there is so much negative in a 6x7 camera. It is actually rather hard to tell the difference between this lens and the others unless you know how far away you were from the subject.
