BillP
Rangefinder General
Now, here's the thing.
There are veritable terabytes of server space on RFF devoted to GAS in all it's forms, and in the why and wherefore thereof.
Something someone said yesterday sent me on an alternate track. Maybe the acquisition of equipment is a control-freak issue.
Let me explain.
You buy a [insert as applicable]. The first time you use it you are dissatisfied with the results - you feel you can do better. You try again, and again until you feel you have mastered the [insert as applicable]. Once you have done that, you start to lose interest - the challenge is mastered, the desired result has been attained.
Of course the alternate can also be true - you never master the [insert as applicable] - results obtained are always flat, not what you are hoping for. You sell it on with a sense of regret, and may even end up buying another in the future to have another go.
So.
This is, I suppose, for want of a better phrase, the "train spotter" theory. That GAS is all about ticking off rather than ownership per se. It's about being able to say "been there, done that", then moving on in search of the next challenge to master. In fact, the last thing it is about is the image.
If this theory holds true, the worst manifestations of GAS can never be cured, because it is about expectation rather than realisation.
Discuss.
Regards,
Bill
Let me explain.
So.
Discuss.
Regards,
Bill
