colyn
ישו משיח
Here's your assignment.. You have a 35mm camera with a 50mm lens. You point it at a near distant subject with lighting from highlights and shadows like you would see on a sunny day. You set your asa to 100 and shutter speed to 125th. You meter it with the builtin center weighted meter and and note the exposure settings indicated..
Now you meter the same subject with the same settings but with an averaging hand held meter from the same spot where you metered with the camera meter and note the exposure settings..
Will both meter indications be the same or will they be different??
