Microdol X anyone?
It has been several years since I used it, but as I recall, it gives you one stop slower than box speed for most films. Also, since it is a fine grained developer, grain is less noticable but pictures appear less sharp. I prefer HC110 or D76 for Tri-X.
Slow Efke films, slow Ilford films, slow Kodak films, slow Arista-Foma films.........all good candiates for Microdol-X.
There is nothing wrong with shooting HP5+, Neopan 400, Tmax 400 or Tri-X at 200-250 and developing in Microdol-X.
Last time I used it would have been back in high school (Class of '78)
I don't recall the results other than for high schoolers it was easy to use...
Give it a go then post the results...
I do remember shooting a bunch of Pan-X and Plus-X back then...
Looking at my old Plus-X negatives I want to buy a ton of the Arista Plus-X from Freestyle. Developers of choice will be Microdol-X 1:1 & 1:3, Rodinal 1:50 and 1:100 and Xtol 1:3 for grins.
And Pyrocat, HD or MC. Pyrocat may be a better fine grain developer than Microdol-X. It certainly is popular among the large format folks.
Expose your Tri-X rolls at their standard speed of 400. Then mix your Microdol-X with water with a dilution of 1:3, respectively, at 74-75 degrees for 18 minutes and you will get wonderful results. I have been processing it in this manner for years and it is a wonderful way to do it!
Thanks guys, I will give it a try soon and post a few pics. Maybe I'll try TriX at 200 AND 400 and see what I get.
I used it in college for Panatomic-X. Shoot the tri-x about a stop slower than normal, so ASA 200 (what's that new thing for film speed???). Also should be good for Plus-X. I remember being able to dilute Microdol-X 1:3 with water and increasing development time for even finer grain.
not w/ you dilute it 1:3. then it's as sharp as it gets.
i suppose it gives a different tonal range.
after trying this and that developer i decided to stick w/ D76 diluted 1:1.
no reason to change.
Thanks! I got a box of HP5+ for my birthday. I think I'll load up the Grafmatic and take the Speed Graphic to the Longview Rodeo. HP5+ and Microphen can't be all bad.
Overexposed (sunny 16 exposed) Tri-X looks real nice in Microdol-X, especially photojournalism. Grain pattern is mushy, but very interesting to look at. Holds up well. Highly silver-solvent developer.
