Minilab VS Enlarger
marameo
4:26 AM
I was wondering if there was a way to tell an analog print from a minilab. I had a lab enlarge a 6x7 color negative on a 20x25 matte fujifilm paper including the negative strip. Because they also advertise their minilab service I am now in two minds..
Behind the print it does not mention the paper, just the brand (Fujifilm). I was expecting something like the type of paper "Archive supreme.."
Also, I can spot a tiny spot on subject hair. Yet, that may be a a dust particle on the negative.
The print itself is good anyway although I wish they could print glossy at this size and larger.
Thanks
I doubt you'll want to do this but if you take a sharpe blade like an xacto and scrape through the emulsion you should see magenta, cyan and yellow layers if it's a wet chromogenic print. Inkjet is sprayed on the paper as a single layer and most likely will have a dot or some sort of color matrix if examined with a high power loupe. Scraping through the ink would NOT reveal different color layers.
I understand the current Fuji mini lab prints are inkjet and not wet prints / chromogenic. The Fuji chromogenic/wet prints I'm familiar with say Fiji Chrystal Archive on the back.
You might ask the lab.
