Timr10
I have a minolta auto meter IV that has been very reliable since I bought it new in 1993. Recently it started giving erratic readings and on close inspection I noticed that a small filter was loose and moving around in front of the sensor. I opened the head up and found 2 separate filters floating around in there. I put them back in place but now the meter is consistantly metering several stops under and it looks much darker than it used to when you view the sensor without the incident dome attached.
Does anyone know how these filters should be installed? Should they all be in front of the sensor and if so what order? Or is one a spare or spacer or something?
Any suggestions would be great.
Thanks
Sent from my SM-N950F using Tapatalk
Thanks
