lscaglio
I'm planning to change my PC, anyone knows if the Minolta dual scan IV in compatible with windows vista?
Thanks
Luca
Thanks
Luca
wintoid
Back to film
Vuescan supposedly works fine in Vista, and still supports all the scanners it usually does. Can't comment on the Minolta, but somehow I would expect trouble.
Kim Coxon
Moderator
You should be able to go online and check the compatibility of your present syatem with windows Vista. That should flag up if there is a problem with the Minolta. Failing that, why not send Minolta an email and ask?
Kim
Kim
lscaglio said:I'm planning to change my PC, anyone knows if the Minolta dual scan IV in compatible with windows vista?
Thanks
Luca
gavinlg
Minoltas long gone unfortunately and sony knows nothing.
My advice - get a mac. Everything works. I can plug in printers from 2000 and they work perfectly. No irritating driver installations etc.
David Goldfarb
If it doesn't work with the Minolta drivers, try VueScan. I rescued my Minolta Scan Dual (I) SCSI scanner that way in XP. Haven't tried it in Vista yet.
