Minolta Mirror Lock Up
JeremyLangford
I'd really Leica Leica
1:03 AM
I'm trying to decide between the Minolta SRT-102 and the SRT-202. The main difference is the the SRT-102 has MLU and the SRT-202 doesn't.
Wasn't MLU added into Minolta SLRs so that some old retrofocus telephoto lens could be used? I probably won't ever need to use that lens and I don't think I will ever be shooting landscapes with 35mm and wish I had MLU to reduce the vibrations. Are there any other reasons I might want MLU?
I will get the newer one, no matter what model it is. I have an old SRT Super sitting in the cabinet, haven't touch it since my dad got the FE2 during 85. Last year, I took it out for clean, the vibrations is much lower that the FE2 from 1 sec to 1/60 even without MLU. The SRT wasn't kept very well so there is a lot of oxidation around the edge of the focusing screen and the meter is not working. Those SRT are very well build.
With telephotos you don't have a clearance problem, but there were two ancient Minolta wideangles from the pre-MC/MD era (W-Rokkor 21 f/4.5 and f/4, respectively). If you're not a collector, just get a newer wideangle such as the 20/f2.8. Minolta lenses are extraordinarily cheap anyway and the lens will be better.
The purpose of MLU was to reduce vibration when shooting from a tripod with relatively long exposures. It can also serve to allow clearance for certain lenses. I don't know about Minolta, but with the old Canon FL system, one of the 19mm lenses had to be used with MLU or the Pellix (no mirror). MLU was once considered a 'must have' for an SLR to be taken seriously, along with DOF Preview.
The Pellix had a mirror, a fixed one:
You can't stick the old non-retrofocus wideangles in there without breaking it.
I have a SRT 101 MLU
even with MLU, tje mecanism that move the mirror works, and make some vibrations
anyway, the camera is quite heavy, so imho MLU is not realy relevant ;)
It is useful when using a ultra wide angle that need to have le mirror locked up (the 17 mm or something like that)
