Mitakon and Soligor 28mm. wide angles.
SCOTFORTHLAD
Slow learner,but keen!
4:58 AM
I have the opportunity to buy either an OM mount Mitakon or Soligor 28/2.8,obviously a lot cheaper than a Zuiko.The use would probably be occasional,but who knows it could grow.Would any one have any feedback on either.
Thanks
Brian.
Brian, - IMHO- you would do better looking for a Tamron, (with 'adaptall' mount) - or waiting for a Zuiko :)
Dave
If you are on a tight budget and what to try a wide angle, those lenses may be fine. I had a Soligor (also sold under the Vivitar name) when I was starting out and on a High School wage and it was OK.
For me, while the optical quality is usually very good on any Zuiko, the biggest advantage is the size. The wides are VERY VERY small, almost RF size.
I'd save the Zuiko.
B2 (;->
Thanks everyone for the advice.I think you have confirmed what I already knew---that I should really look for a Zuiko.Luckily another member may have one to spare,so it's going that way:)
There is a large scale reconstruction underway of the 19th Century waterfront area where I live,and I want to record it,and with a wideangle I might be able to get something memorable.
Brian.
Brian, I know this maybe too late, but if you can get the Tamron 28mm/2.5 Adaptall-2 for cheap, that lens is very very good. It is almost as contrasty as the Zuiko 24mm/2.8 and that's saying A LOT.
sample:
oversharpened by flickr, sorry.
Brian.
Brian the 28/3.5 Zuiko can be had over here for $30-$40 on eBay and it's a crackin sharp lens for not much more than a Soligor. I once owned and used a late model Vivitar 24/2.8 in Pentax K and it was pretty decent -- they have an OM versions and I think 28mm models too.
sample:
*Nice* shot -- I'm off to look for of those now for my Nikon F!
Brian,
This is not firsthand experience but IIRC Mitakon were rather budget lenses with budget performance. Soligor had the better reputation...
Tamron were always considered the best non-OEM, although I confess to never having owned any.
