Modify Polaroid Back For Fujifilm GX680?
wjlapier
8:51 AM
So, this is a question--I haven't done it yet. I'm wondering if anyone has ever modified a Polaroid back for a Fujifilm GX680? Basically Dremel some of the plastic away so you could expose more of the film. I see you could Dremel the corners in the circle to make a square photo and it might not affect the back. There is a electronic panel that isn't connected to anything but there is a tiny pin that might notice the dark slide is in or out. That's all I can see the electronic panel will do other than maybe communicate to the camera that there is a Polaroid back. You can see in the photo the area that didn't get exposed, or the area that is cut off on the corners.
What about the corresponding opening on the camera body? Wouldn’t it limit the image size before it even gets to the back?
