More on Helios 103 filter size
oldgeezer
3:32 PM
I have measured the O.D. of the filter ring on the lens and it measures at 42.15mm, the filter ring is not dinged or dented and the filter threads are clean. The I.D. of the filter ring measures at 40.0mm. The O.D. of the 40.5mm Tiffen filter measured at the threads measures 40.35mm. Serial on lens 8143347.
I believe that those fsu lenses take a 40.5 filter.
The vintage Canon ltm lenses are tricky, with a 40 filter iirc.
Just seen a Jupiter 8 and filter etc advertised and the filter has "40,5 x 0,5" written on it. Hope that helps.
Regards, David
Could it be that there is some 'slop' to allow for small dings in the filter mount preventing an exact thread of 40.5mm from being mounted? It wouldn't take much to make it next to impossible to mount a filter under such a condition as an exact match.
Use a loop, magnifying glass, or 50mm lens to examine the entry threads of both lens and filter and look for damage/deformation.
