Q
qaiade
Guest
Well my Canonet is still broken. I havent been able to remove the rear element and I've done considerable damage to the ring by trying. The wierd thing is that the innermost ring and the outer most ring turn easily. So I loosened the outermost ring which caused the the lens to separate from the body. I noticed a screw (first photo) that appears to keep the middle ring in place. Should I remove it or will that cause more problems? Also after separating the lens from the body I forgot the position of the gray metal ring (photo 2) and now the body and the lens wont go together properly. Finally the aperture blades have rusted , can they be cleaned? i plan to dissemble the lens to figure out what is jamming the rings, but I thought I should deal with these issues first.
