Moving from a C-V 75mm to a 75mm Summarit...?
Ken Ford
Refuses to suffer fools
12:51 AM
Central TX, USA
I'm considering selling some gear and replacing my trusty C-V 75 with a new Summarit.
Can anyone here that has the 75 Summarit offer an opinion on wide-open performance?
Thanks!
The CV 75 is mighty good for value, performance is equally acceptable.
Having used it on M8, I can say . . . I actually think highly of it.
I don't have the Summarit 75. Perhaps it's performance might be stellar, so I don't know.
This is no way proper way to compare a lens . . .
but comparing it to my Elmar 50/2.8 (latest version), the contrast, and sharpness of CV75 is very good, if not on par.
What I am trying to say is . . . the performance gain might hardly be quantifiable.
I wish it were better wide open - stopped down to F4 it's fine. It's not unsharp at F2.5, but it doesn't have the razor-sharp feel my 35 ASPH does at F/2.
I'm curious how the Summarit is wide open. I really doubt I can afford a 75 Summicron.
(Subscribes to thread)
This is really a great question. The VC is the entry level, and the Summarit is the next upgrade step. (The only next step pricewise, as sadly ZM has a gap here.)
Erwin, FWIW, say that the 35 and 75 Summarits are the better of the 4. And that they are both close to the Summicron versions.
I think Erwin Puts reviewed the Summarits, and if I remember he really liked the 35mm and the 75mm. Have you checked his site?
if you really like the razor-sharp modern cron look that your 35 ASPH gives you (center and in the corners) and want the same in the longer FL, then save for the 75 cron.
I owned a heliar before I got lux fever. I have shot both the cron and the summarit and both are very good. You might be surprised if you read Sean Reid's site, that the heliar held up pretty well when he compared it against the cron. It is worth the subscription price if you are thinking of making this move. Maybe you can find a summarit to try out against your heliar before you put out the money.
Well, I've tried both.
I'm not sure I'd trade the Voigtländer for the Summarit, but the Summarit is enough better in my book that if I didn't have a 75, the Summarit is well worth the extra.
I own a Summicron, and it's superb: a 'magic' lens. If I didn't have that, I'd seriously consider a Summarit. For wide-open performance, and close-ups, the Summicron is (unsurprisingly) better, but the Summarit is very good indeed.
You might find this interesting:
http://www.rogerandfrances.com/photoschool/ps firstlook summarit.html
or of course you might not.
What I really want is a 75 Cron (no thanks to Roger's article that got me interested when first published, grumble grumble). The C-V 75 was always meant to be a "placekeeper' lens for me to see how I liked the FL on the M6. It handles differently enough from a Leica lens to be a bit of an annoyance, but it has served its purpose with distinction - it is a very nice lens.
Unfortunately prices are out of control and a 75 Summicron may be forever out of reach unless I start pimping out my wife and dogs. A Summarit, while not inexpensive, is at least doable if I sell of some unused gear.
I feel a tremendous need to simplify my kit with less stuff and concentrate on what I really want.
FPJohn, thank you - that's exactly the kind of comparison I was seeking.
Sorry Ken!
I often wish I were nearer so many of my correspondents so they could just try some of the gear I have. Handling it, and comparing test shots, is the only way to tell if something really suits you.
Roger
I consider the 75 Cron as one of those lenses that is at the zenith of lens design. Image quality wise, only the 50 ASPH and the 90 AA seem to be able to equal it.
The way I read this thread, it would make the jump from the CV to the Summarit mostly a question of build quality and handling rather than image quality. Aperture and minimum focus distance are nearly the same...just wish I could see differences between the images taken by the two. Here is another discussion of the CV in a positive light: http://www.rangefinderforum.com/forums/showthread.php?p=715643#post715643
Sounds like the stratospheric choices ('cron and 'lux) have deservedly good reputations, but are way out of my range. In the absence of a ZM option, sounds like my best choice is the CV Color Heliar. It just doesn't sound like the Summarit offers that much substantial difference, if any.
Does anybody know a place where photos taken with the CV and the Summarit can be seen side by side?
As it happens, I have just been shooting with a Summarit 75f2.5 over the last couple of days. My friend Terry Cioni bought one and graciously lent it to me.
a/ Going from the CV 75f2.5 to the Summarit 75 you will see a slight improvement in wide open performance. Not staggering, mind you, but slightly better edges than with the VC.
b/ It is not a small lens! I expected it to be close to the VC in size, but it is actually closer to the Apo Summicron 75. I did put a shot of the four 75's on my Flickr site a couple of days ago and there you can see the difference.
c/ If I had a VC 75, I would be hard pressed to spent the $12-1300 for a Summarit 75. I think I would rather save up for a 75/2 Summicron instead! As Roger says, it is a spectacular lens. In my estimation, one of the best Leica lenses ever! It is particularly good in close up and wide-open. If you are used to the edginess of the 35/2 Asph, nothing will really satisfy you until you get the 75f2 Summicron. So a couple of month on "hambutger helper" and macaroni and cheese is rough, but you will have the best Leica lens made!
I know, this is not much help in trying to avoid the inevitable (the 75f2), but thats my opinion.
Of course, with the introduction of the C-Biogon 35/2.8 from Zeiss, I would suspect that we will see a 85f2.8 C-Sonnar soon enough (pure speculation though, but it does kind of fit) and with the quality of the current C-series, the 21/4.5, the 50f1.5 it could be a worthy contender and most likely outperform the Summitar 75!
