usccharles
everytime i change my SD card, my counter resets to L100001! i have so many pictures with the same file name that i'm having to save every card in a separate folder in my computer.
help! what am i doing wrong??
i think this started after firmware 1.102 FYI
HansRoggen
Do you have picture number set to 'continuously'?
Hans
Hans
usccharles
yes. it is set on continuously. this should be correct right?
what does 'standard' do? sorry i don't have a manual handy
jaapv
RFF Sponsoring Member.
I must confess I hve not figured this one out either...
grduprey
Gene
mine keeps couning from the last number, even when changing sd cards. the menu item is set to continuous.
gene
gene
HankBar
I used three cards on a trip, with only one card the M8 started counting anew. I still have to figure out why.
HansRoggen
Just guessing here, because it sounds like you're doing everything right but have you tried resetting your camera yet? And i take it you are not formatting your cards on your computer. Does it happen with all your cards?
Hans
Hans
usccharles
actually it never happened before the newest firmware update. i do format my cards on my camera time to time. haven't reset my camera in awhile. i'll try it.
seems from the responses that this is not an isolated problem. LEICA, HELP, PLEASE FIX!
usccharles
Doh! i'm an idiot!
Doh! i'm an idiot!
HA! i found out what i'm doing wrong! somehow when i saved one of my profiles, i had file numbering set to 'standard' in that profile. per the M8 manual, 'continuous' is exactly that, continuous numbering, but 'standard' resets your numbering everytime you change your SD card.
i'm such a doof.
Doh! i'm an idiot!
i'm such a doof.
HansRoggen
Hehe...well, such a doof...you're the first to figure it out in this thread, so that probably means you're officially de-doofed again.
Hans
Hans
jaapv
usccharles said:HA! i found out what i'm doing wrong! somehow when i saved one of my profiles, i had file numbering set to 'standard' in that profile. per the M8 manual, 'continuous' is exactly that, continuous numbering, but 'standard' resets your numbering everytime you change your SD card.
i'm such a doof.![]()
Now I know what to check for!!
Fellow-doof
