My new Pentax MX and first test roll
kb244
8:45 AM
Yesterday I received a recently (November 2016 by Eric Hendrickson) CLA'd Pentax MX with a Pentax-M 28/3.5, I already had three Pentax Mount lens (Pentax-M 50/1.4, Rokinon 85/1.4, Tamron SP Adaptall 90/2.8 1:1 Macro) hence the reason was looking for an SLR counterpart to my rangefinders. Plus the general consensus was they had very large/bright viewfinders, but I also wanted to make sure it was fully mechanical outside of the meter.
I went with a formula I found on filmdev.org which calls for stock solution of Microphen for 7 minutes at 68F, course what I didn't realize was that when I set the film speed on top, I must have bumped too far or wasn't attentive enough to notice I put it 2 dots past 400 and was metering for ISO 640. Results still came out, and the massive dev chart shows 640 at 8 minutes, so that explains some head scratching when I was thinking the meter was going a little higher than my guesstimate would have figured.
I'm curious though if the standard 01 screen is sufficient enough for focusing with the f/1.4 lens, I feel like result wise it's not spot on the exact spot, but I was relying more on the microprism ring than the split line, guessing the split is more accurate to "see" in those cases. Though would like to try to see if I can find an SA-3 screen (designed specifically for lens with a maximum aperture of f/1.2 to f2).
I scanned these on my home Canon FS4000US scanner which I prefer over the school's flatbed, but later tonight will be doing some wet printing (some of these might look pretty nice on the Oriental Seagull VC RC II paper I recently got). A number of them are at the GRAM (Grand Rapids Art Museum), then headed back towards campus to snap some spots I usually snap. Most the indoor ones were shot at f/1.4~2, and 1/60th~1/125.
I didn't, the previous owner did and it was about 87 according to the receipt shown on the ebay auction.
Forgot to mention, the Tri-X roll was given to me by the professor who knew I liked Tri-X. It expired late last year (December 2016), so I don't think a couple months expired would have any impact, but I also don't know how/where he stored the roll. So if the grain seems *more* than expected, that might be why.
I didn't have time to wet print today, too busy with the digital lab, but I did develop the second roll using the sprint chemistry. Just stuck it on the flatbed in the sleeve and just did a quick scan of it.
The notes I took as I shot each frame (also noticed that I wound one too many and started on '1', instead of '0', so there's 35 frames)
Frame 1 : 1/125 f/2.2 50mm
Meter shows green in center of frame
Prints on the wall.
Focus using split on edge of print on Wall.
Frame 2 : same but with 85mm
Frame 3 : same as 2, portrait orientation, focus split prism on edge of flower and bowl prints.
Frame 4&5 (50mm): 1/250 f/1.4 meter shows half a stop over (1/124 would be half under)
Focus on edge of ruler. First one by microprism, second by split and micro really close.
Frame 6 and 7
1/125 & 1.4
1/60 & 2.2
Meter green on both checker shots.
Split focus on #5 on right edge of circle
Microprism focus on neon sign towards left of word got #6
Frame 8 - 16 (50mm f/1.4)
Focus on second thumbtack at the metal pin, via horizontal split prism
Incident Meter Reading 1/1,000 @ f/1.4 for ISO 400, shooting +1 over.
Frame 8: 1/500th @ f/1.4
Frame 9: 1/250th @ f/2
Frame 10: 1/125 @ f/2.8
Frame 11: 1/60 @ f/4
Frame 12: 1/30 @ f/5.6
Frame 13: 1/15 @ f/8
Frame 14: 1/8 @ f/11
Frame 15: 1/4 @ f/16
Frame 16: 1/2 @ f/22
Frame 17: (90mm f/2.8 Macro 1:1)
1/500 @ f/2.8 (incident metered to the same)
Focus on center thumbtack with split right on the metal barrel/shaft.
Frame 18 : 1/500 f/2.8 (closer crop, focus approx 0.305 meter)
Frame 19: 1/1,000 f/2.8
Frame 20: 1/250 f/2.8
Focus on closest strip of paper towards lens. Focus approx 0.33m
Frame 21: 1/250 f/2.8 (incident meter reads 10EV + 2/3, so barely 1/3 under, reflective shows 1/2 under light)
Focus on grid directly behind all paper strips, 0.34m
Frame 22: 1/250 f/2.8 (reflective shows green)
Focus on closest strip of paper towards lens on top of wood
TTL Meter shows green for 1/250 @ f/8
Frame 23 : 1/250 f/8
Frame 24 : 1/125 f/8 (+1 over previous, shows +1/2 over on LED)
Focus on wood grain (Incident shows 1/250 @ f/5.6 , EV13)
*almost* 1:1 life-size, reflective shows -1 (red) LED for 1/125 @ f/8
Focusing attempt was primarily between the matte and micro prism ring. Split was getting difficult to eyeball exactly.
Frame 25: 1/125 f/8
Frame 26: 1/125 f/5.6
Frame 27: 1/125 f/4
*Rokinon 85mm f/1.4 from this point*
Frame 28:
Incident meter shows 9-2/3~ 10EV (1/500, f/1.4)
Reflective says +1 stop over (top red LED)
1/500 f/1.4
Focus via micro prism ring on the chrome trim in the middle of the Pentax-50/1.4 lens.
Frame 29: 1/500 f/4 (Same as above, but with green Reflective LED, which brings it to exposed for the background)
Frame 30: Selfie attempt with timer
1/125 @ f/2.8, pre-focused on ledge of window still, then re-composed.
Frame 31: Drawings on hallway, Focus on left edge of the 4th drawing on the bottom row. Roughly split and micro prism seem to match on the vertical.
1/125 @ f/2.8
Reflective meter was put at +1/2 overexposed at the area of the drawings, when recomposing with the shadow area in the center of the frame, meter showed green LED.
Frame 33: 1/250 f/1.4 (meter green at center)
Frame 34: 1/125 2.2 (meter green on brown top portion)
Frame 35:
Focus on second hanging light closest to lens
1/125 2.2
Set meter to show red (-1) on a black painted podium/stand.
Some scans from that second roll. Also I disassembled and cleaned my Pentax-M 50/1.4, cleared some dust out of the cam and what not, which is why in the sequence the very last shot at f/22 appeared overexposed and not equivalent (f/16 and f/22 were of the same diameter as it didn't stop down any further).
For this third one, in photoshop, if you were to add a hue/sat or flat color blended layer, and double click the layer under "Blend if...", you can drag the black slider down to around 124, then hold alt and drag the left half of it back down towards 10. What will happen is that color will only show when the image's luminosity is above that range (in this case the highlights which in reality are bright red lights), the alt+click makes the transition smoother rather than just clipping right off when it hits a certain threshold, then you do another, but for the white pointer, kind of one non-destructive way to do split toning digitally.
1) I like the MX for tactile and size reasons
2) Grain is a bit too much for me though
3) Someday I'm gonna get me that Tamron Adaptall 90mm 2.8 lens.
4) Ever tried the Revuenon 50mm 1.4? It's a Chinon 50mm 1.4 clone with different coating, and almost as nice as a Summilux (gasp)
Whoa, that's a lot of oversized files!
I'm confused, is there an actual question buried in here? Looks like the camera is working. You seem able to focus.
I have five Pentax SLRs (and two more digital Pentax), they all have been great. My first was 1969 Spotmatic, but I have never owned an MX. Maybe one will break and I'll buy one. Every thing looks good with you new photos.
Cheers!
No question (would have been if there was an issue, and the the issue with f/22 was noted on apug), showing off, and 1080p isn't oversized.
But yes, focus appears to be ok, but did figure out that f/22 on the 50mm wasn't shopping down any further past f/16, so cleaning helped fix that.
Shot of the camera itself.
