need help on jupiter-9
fabrice
7:15 PM
Hi there, you FSU RF freaks :D
I started shooting with a jupiter-9 on a zorki 1. ha ! I know it's bulky and not very cute to see ...
But I'm waiting for a zorki 6 that should be better I reckon.
Anyway : I got stripes, milky ones, horizontally. Sometimes one, often two, on some pics I made with the j-9.
I first thought of light leaks on zorki's body.
Now, I shooted in the same conditions, the same minute, with a j-11, that's perfect.
I guess it's some kind of flare, I didn't use any sun shade.
But I wanted to be sure.
I peeked through the lens, from rear, and found that the subject aimed was pictured, like a ghost, in the rear lens. Is it normal ? Is it somethnig that can be fixed ?
thanks !
Could you post an example of the problem shots? You might want to be sure that it is not a film or processing problem before you actually start dismantling the lens. It is one of the harder ones to work on.
-Paul
Hi and thanks for the helping hand.
Of course I'm not into fiddling in it just for the fun.
Especially knowing it's ok and giving accurate aming !
I first thought the process was wrong, I must confess it was a cheap one :D
So, I tried the best lab I know in town (hu, twice the price, you bet they are good !) and the problem stays the same..... anyway, my other pics (with J-11, and J-3) were so good with that lab I'm gonna stick to this one !
Anyway, it couldn't be a light leak while changing the lens, could it ?
I don't seem to find the same issue with other lenses.
Mind puzzling it is :bang:
edit : I can't show you a pic, don't have any scanner !
