C
ch1
Guest
I found what I'm told is a Contax IIIa at an antiques store. Nameplate says it was made in Stugartt, Germany. Leatherette is still okay although you can feel the backplate rivets - but they haven't "popped through".
The RF seems realtively bright and it has a ZI Sonnar 50mm (5.0cm?), 1.5 lens attached.
I removed the lens and it does appear to have some oil on the blades but the glass is clean. I do not detect any indents when I move through the aperture settings (i.e. it moves very smoothly rather than distinct "clicks") is this normal? The lens may be coated, I couldn't tell for sure.
I opened it up and pressure plate seems clean - I had a "sales guy" hovering over me and no countertop to rest things on so I did "fiddle" with it much. I did note that the take-up spool was not "attached" to the winder so it came off in my hand - is this "normal"?
Obviously, I know next to nothing about Contaxes so any info is appreciated.
Oh, the asking price, with leather case (broken strap) is $150. Does that sound "reasonable" figuring it will at least need a full CLA.?
