Need Lens Info
DeeCee3
9:08 PM
I'd appreciate some guidance as to desirable FSU lenses in M39 mount to be used with an LTM>M adaptor. I have one, a Jupiter 8 f2, which has given me good service but I'm simply not familiar with what's available in other focal lengths.
I'd like something wider as well as something in the 85-90 range. Low price is definitely a positive factor!
A tip on vendors of these lenses would be welcomed, too.
dc3
What camera body do you plan to use it with ?
In 35 there is only 1 lens - Jupiter 12 35/2.8
( more info here: http://www.griffinbyteworks.com/photography/equipment/jupiter12.html )
In 85 there is also only 1 choice - Jupiter 9 85/2
If you plan to use a the 85/2 on a non FSU body, expect that it won't focus well close up and wide open, unless you get it collimated and the focus adjusted for Leica standard.
(about the compatibility of FSU lenses and Leica bodies read here: http://www.dantestella.com/technical/compat.html )
Great Information
Great Information
I really appreciate the links and found the material extremely informative. I'm planning to use the lenses on a CL (being careful of the meter stalk, of course). Thus far, my Jupiter 8 seems to render acceptably sharp images.
dc3
