HHPhoto
there are some good news for users of 127 format Baby-Rolleiflex, Yashica 44 and other classic 127 cameras.
4 (!) new 127 format films are available from Rollei-Film, Germany:
Rollei Retro 80S (that is Agfa-Gevaert Aviphot Pan 80, current production from Agfa-Gevaert, Belgium).
Rollei Crossbird (that is Rollei Digibase CR 200 = Agfa-Gevaert Aviphot Chrome = original Agfa RSX II 200 emulsion coated on PET base).
With this film the "Super-Slide" is back. 4x4 slides can be projected in every normal 35mm projector.
This film is also for photographers who like cross-processing in C-41, because this emulsion (Agfa RSX II 200) is quite popular among crossers.
Rollei Redbird: Film with ISO 400/27° for redscale photography.
Rollei Nightbird: Film with ISO 800/30° for redscale photography.
My own experiences with Rollei Retro 80S:
I have tested this film intensively over the last months (so far only in 35mm). My results:
Positive:
+ Extremely fine grain: It is the finest grain film in its speed class, grain is significantly finer than even T-Max 100 and Acros 100. I have used different developers, and even in developers which give coarser grain like Rodinal, RHS/Amaloco AM 74, Spur SD 2525, the grain of Rollei Retro 80S is finer than TMX and Acros developed in fine grain developers like Perceptol and Spur HRX-3.
I have tested it again and again: This film with classic cubic crystal technology has finer grain than films with T-grain, Delta or Sigma (Fuji) crystal technology.
In 35mm I got grain similar to 6x6 Fp4 + or 4,5x6 APX 100.
I am using this film in 35mm for some photographic needs where I have used 120 film in the past.
+ Excellent resolution: Resolution is on paar with TMX and Delta 100 (I have got up to 150 Lp/mm with my Zeiss lenses), and a bit better than Pan F+ and Acros 100.
+ Excellent sharpness: On paar with TMX and Delta 100.
+ In 35mm the film is drying absolute flat, no curl at all.
+ Extended red sensivity: With red filter you can cut through haze and get excellent detail in landscape photography (here you see that this film is Agfa-Gevaert Aviphot Pan 80 aerial film; in aerial photography you need this feature):
Furthermore with IR filters IR photography with very good results is possible. You get a complete different look, because with this film you can make extremely fine grained, sharp high resolution IR photographs. Complete different look to HIE and Efke IR film.
+ Excellent smooth, light skin tones in portrait photography (due to extended red sensivity and the extremely fine grain).
+ Clear base: Excellent for reversal processing.
+ PET base: Best long term stability, excellent for archival purpose.
+ Available in 135, 127 (!) and 120 format.
+ Attractive price (at least here in Germany, check for your country).
Negative:
- Exposure latitude is a bit smaller than TMX, Delta 100 or Acros 100.
- Loading in subdued light is recommended because of the clear PET base.
Result: This film is outstanding, one of the best and most versatile films on the market. Available in 135, 127, 120.
Highly recommended.
Jan
Positive:
Negative:
Highly recommended.
Jan
